Hi, I have a 20x40 in ground pool. The pool has always had enough suction to operate a 1.5" skimmer suction hose that attaches to the end of a pole- but just barely. Last year, i replaced the 1.25 HP pump with a new 1.5 HP pump. I also replaced the 1.5" 3 way diverter valve as the old one was damaged when a toy lodged in it (found when I had the lines snaked bc I couldnt get enough water to prime the pump. Afterwards, the system would circulate, but it will not get near enough suction to operate the skipper hose which I use to suck leaves out of the bottom. Also notice that the clear section of the pump above the basket does not fully fill with water- nearly, but not fully. Any thoughts as to what would cause the pressure reduction and how I can boost it back up?
I have a Hayward pool heater (not running due to low pressure switch) and sand filter. The purchased pump is this one:
Thanks!
Thanks!
