I've had my pool for 8 years no and relied on my local pool store ever since. This pool season they closed the doors so I decided to take matters into my own hands.
I have a taylor test kit these are my current readings.
FC 1.0
pH 7.4
TA 170
CYA 0?
CH 270
A bit of history.
I tried my new Taylor kit last night CYA I am assuming is zero. The sample never got cloudy therefor the black dot at the bottom of the tube never went away. When I tested for FC I called it a 1 but it was questionably zero as well.
So, I have done a lot of reading today in regard to CYA and FC. My plan is to get 4lbs of dry stabilizer tonight to start with. I believe if I can get the CYA up to 30 I may start getting FC readings,
I also need to get some acid and start lowering my TA.
And yes I am switching to SWG next year. I was lied to. Pool store told me there's a reason they don't sell them... I never asked for their reason, I just trusted them.
FC 1.0
pH 7.4
TA 170
CYA 0?
CH 270
A bit of history.
- I am using 3" tabs in my chlorinator set to 3. And shocking weekly with 73% CAL-Hypo.
- 4 years ago I had seriously high CYA levels that was using up every bit of shock I dumped in. Very expensive year.
- Following 2 years I drained 1/2 my pool. Test strips would show zero CYA. I figured I solved the problem. 0 is better than 400 or whatever it was in 2021
- For the last 3 years I could not get a FC reading on test strips or at the pools store. Water was always clear so I just shrugged it off.
- In the last 2 weeks since opening I have added 6 gallons of liquid chlorine
