Moved from here: What piece of plumbing makes the bubbles in the spa?
Have a problem that seems related to this one. I’m not getting bubbles at all. Water flows out of the aerator ports when the spa is on. I drained the spa, took out the jets, removed the port caps, reinstalled the jets, made sure they were open, and still pumped lots of water out the aerator ports. Filter was cleaned this week. This was going on before it was cleaned. If I pull two jets, then water doesn’t flow out the ports; no bubbles. The jets are 19 years old. Do they wear out and reduce flow to the point that this would occur?
