Nixie Pool Controller Priming Not Working Pentair Superflo
raidflex
6
Southbury, CT
Hey All,
Wondering if anyone was able to get priming to work via the RS485 connection through Nixie?
I have a Pentair Superflo VST setup with the Nixie Pool controller and everything works except the automatic priming. I did set the manual priming speed to 0 which the manual said to do when using the RS485 connection for control.
But the pump will never engage priming when turned on via the RS485 connection, it will just set the RPM to the pool schedule I have setup.
I can't set a manual priming speed either, as this is ignored when the pump is setup to use the RS485 connection.
I posted on the GitHub for Nixie but never received any help.
Everytime I clean the filter basket I have to manually increase the RPM so it has enough suction to prime, which is kind of annoying.
