I had my 16,500gl vinyl lined pool opened a couple weeks ago and I have no idea what they put in it but I'm guessing nothing they haven't used before. I've had all my other chlorinating systems off so far, wanted to get everything balanced before thinking about maintenance. When the pool cleared up I noticed a TON of iron stains all the way around the pool, mostly where the wall meets the floor. I tested with Vit C tablets to confirm it was iron. I let the FC drop to zero, my ph was already 7.2 so I left it there then I added two bottles of Metal Magic (just slightly more than called for based on my gallons). The MM lifted some stain but not a lot (I also backwashed and rinsed numerous times). My pool store was out of Polyquat 60 so I added two bottles of Polyquat 30. I then ordered 2lb AA online and added that. A couple days later all the stains were gone so I was ready to sequestor the stains. I had to go to a different pool store so unfortunately I couldn't get more Metal Magic or Polyquat 60 so I ended up with Metal Free instead, a bottle of Leslie's Algae Control 60% (which says it's poly) and a culator which I tossed into the filter pump.
At this point my stains are gone but my water is super cloudy. I thought I was ready to start bringing the FC back up so I just went out did all the tests to figure out what I need to get. Results:
FC: 0
Alk: 80
ph: 6.8
Hardness: 300
Before I make some grave error, my plan for tomorrow is to bring my alkalinity down, raise my ph and start slowly adding liquid chlorine. I'll pick up some more sequestrant in case I see stains come back, and I'll keep regularly backwashing in hopes of getting rid of some of the sequestered iron.
What am I missing? It takes me an hour roundtrip to the pool store so tell me what I need to have on hand or that I am getting wrong or forgetting!
FC: 0
Alk: 80
ph: 6.8
Hardness: 300
