I have a question.
As a COMPLETE hot tub newbie, I have been trying to fix things on my own.
BUT!
We live in the foothills of the mountains of SE Arizona.
Our water is so hard that even our household things like the shower, ice cube maker, etc. are inundated with probably calcium.
Here is my hot tub chemical info:
Chlorine: 5ish
pH: usually > 9, easily reduced to 7ish
Alkalinity:around 200, easily reduced to 120 but have not been successful on getting it lower.
Hardness: about 500-600, 1st refill >800
Cyanuric Acid: Probably 200-400 ---does not measure/ as Too High. Probably over 4-500.
We are using 6 way test strips from a general merchandiser, as this hot tub itself is 2nd hand .
Dear Sir,
I am trying to make our2nd hand hot tub safe for our use.
It is used around 2-3/week. Otherwise covered from the UV input.
(Our UV stuff is astronomical in Southern Arizona)
Can you please suggest how to fix our Cy acid levels? Our even if that should this be our first concern?
Any suggestions are truly appreciated,
E.
BUT!
Chlorine: 5ish
Dear Sir,
E.
