Hello!
I'm a new Homeowner and Pool Owner as of 3 weeks now. I hired a pool guy but two things are going on, 1. I've always wanted to learn. 2. I don't trust I'm getting the best maintenance because if I don't ask my service guy won't check further. Their service takes less than 10 minutes, which includes (in order): vacuum, brush, throw a cap of a liquid (not sure what) I've also not seen him check the chemical levels unless for that 1 time that I asked).
Anyway, after much reading and buying my Taylor K-2006c and an additional kit for the salt reagents since I own a saltwater pool.
I've always asked my pool guy about chlorine levels and alkalinity since the strips I used always showed TC very high while FC was in the normal range. Alkalinity was always 0 on the strips. After a test with his own strips he said alkalinity was fine since PH seemed fine but that chlorine levels were high so he turned the chlorine generator down to 1%. This was yesterday.
Today, I was finally able to put my Taylor kit to use for the first time.
PH 7.6
Alkalinity 60 ppm
FC 12.5 ppm
CC 1 ppm
Hardness 210~220 ppm
CYA 40 ppm
Salt 3400 (from my test; chlorine generator states 3100)
*The chlorine test was confusing to me, so I did it twice. The first time with 25ml it took FOREVER to turn it clear, but that was unreliable since there was always a very clear shade of pink if looked from the top. From the front, the water looked clear. So I got rid of that test and tried again with 10ml this time. I'm still not 100% sure of when to stop on that test so my number for FC might be wrong. Please advise on how to best do this one.
Any advise would be greatly appreciated. I plan to maintain the pool myself after my pool guy's last service next week.
Thanks!
PH 7.6
Alkalinity 60 ppm
FC 12.5 ppm
CC 1 ppm
CYA 40 ppm
Thanks!
