Thanks everyone for such good advice!
One thing that I failed to mention, after I tested this morning, is that I had already tested last night to and when my ph was 6.8 and my FC was 0, even then. I took it upon myself to add a supper chlorinating tab (HTH ones, 3 in) in a floater and put it in the water(this was last night by the way). So, thats why I tested this morning to see if something might have change, but it stayed the same. So, sorry, I failed to mention it before.
I did put 60oz of borax in my skimmer this morning and it brought my ph up to more than 8.2. (A little high) :| So, I'm going to add about 1 bottle of 6% bleach in the morning ( 96oz), (first I've added since shocking) and run my pump for 4 hrs. and see what the results look like. Hope I'm doing something right! I will share my readings with you all sometime tomorrow. (We'll see)
Leebo, I like how you worked out the weekly schedule. I may end up doing it that way, but since I already started out this way, this is all I know what to do. If by using the chlorine pucks, it messes with readings, could someone let me know, cause I'm dieing to do this right!
I always welcome help! You all are great!
