T Timtraver New member May 14, 2022 2 Houston May 14, 2022 Add bookmark #1 Trying to use CSI calculator. Stuck on setting up a pool name. Can’t get past the setup screen.
Texas Splash Mod Squad TFP Expert LifeTime Supporter Jun 22, 2014 52,015 Texas, San Antonio/Marion, South-Central Area Pool Size 17888 Surface Fiberglass Chlorine Salt Water Generator SWG Type CircuPool RJ-45 Plus May 14, 2022 Add bookmark #2 Welcome to TFP! Are you using the PoolMath APP? Gone to settings?
Leebo Admin TFP Expert LifeTime Supporter Jul 21, 2011 12,977 Eastern Ohio Pool Size 25000 Surface Vinyl Chlorine Liquid Chlorine May 14, 2022 Add bookmark #3 In the upper right hand corner there’s a check mark. Make sure you're pressing that to save the setup. WELCOME TO TFP!
T Timtraver New member May 14, 2022 2 Houston May 14, 2022 Add bookmark #4 Timtraver said: Trying to use CSI calculator. Stuck on setting up a pool name. Can’t get past the setup screen. Click to expand... Yes I downloaded it and it took me to the setting up the pool name. Never could get past the screen
mknauss Mod Squad TFP Expert Bronze Supporter May 3, 2014 62,672 Laughlin, NV Pool Size 6000 Surface Fiberglass Chlorine Salt Water Generator SWG Type Pentair Intellichlor IC-40 May 14, 2022 Add bookmark #5 Timtraver said: Yes I downloaded it and it took me to the setting up the pool name. Never could get past the screen Click to expand... Email [email protected] and you can get some direct assistance.
