Newbie Testing
greggjess
Active member
Jun 16, 2021
40
Fort Worth, TX
Fiberglass
Autopilot Digital Nano+ PPC2
I just got my test kit on Saturday. This is on a new pool where the builder shocked it a few times then added salt and SWG.
Sat test
PH 8.2
FC 0
CYA 0
Per PoolMath App instructions I added 4 lbs CYA (.5 lb-ish still undissolved), 17 oz MA and increased run time (from 8 hrs to 11 hrs) on SWG. I'm still learning how to manipulate the purification % on my SWG.
Today's test
PH 7.5
FC higher than 5 (it was really bright yellow)
CYA 50
I feel like I'm headed in the right direction so I guess my question is where should I put my runtime and purification % for the SWG? The hubs likes to run the pump all day to keep the surface moving so we have it set for 10am-9pm right now.
Not sure if it is in my siggy but we have the AutoPilot PPC2+Nano.
Congrats on your TF-Pro tests. In the future, please list them as follows:
FC
CC
CYA
PH
TA
CH
From what I see here, you improved considerably. I would still increase the CYA by another 10-20 ppm so that you get closer to 70 minimum CYA. For the FC testing, use the FAS-DPD (powder & drops) as that will provide a very accurate FC number. Also post your TA next time just so we can be sure it's okay. CH shouldn't be a big deal with fiberglass, but go ahead and post that next time as well.
You're doing much better now than before. :goodjob:
I'm slowly getting my way through all the tests...baby steps so my head doesn't explode lol
My salt test just said 4400ppm :oops: I'll test again tomorrow and this time do ALL of them.
Reactions: Texas Splash
Reactions: greggjess
