Thanks to this forum i have finally decided to manage my own pool. Before that I had a pool guy do the last filter clean.
Here are the particulars
I have a Pentair FNSP 48
We had 4 grids with small tears so I replaced them with a full 8 set
Pool filter area is 48 sq ft
The pool guy said he added 10 lbs of DE (should he have added 5 lbs - i did question him, he said since they are new, more DE is needed. I didnt see him measure could have meant he added 10 - 1 lb coffee cans full which would be 5 lbs) anyway not seeing any DE in the pool so assuming he added 10 coffee cans or 5 lbs
We also had drained and refilled with brand new chemicals and fully clean pool. He put all new chemical and asked me to run the pump for 8 hours.
The pressure started off with 15 psi but after 8 hours now is showing 25 psi.
Should i be worried? The max rated pressure for filter is 50 psi.
Should i add more DE - what should i do?
I am on my own now.
The next time i backwash am i supposed to add 4 lbs or 8 lbs.
Thx
SaGu
I am on my own now.
Thx
SaGu
