Welcome to TFP!
Starting your chems with a fresh fill is pretty standard here really. No magic potions required.
Consider the following:
- New water has no CYA (stabilizer), so be prepared to add at least 30-40 ppm of stabilizer. We recommend the sock soaking method.
- While the sock is soaking, add about 2-3 ppm of liquid chlorine to the water on day 1.
- Test/adjust your pH anywhere between 7.2-7.8.
- TA may require some adjusting, but it's not a huge priority.
- CH shouldn't apply to you since you have a vinyl liner.
Once that sock has been soaking for a good 30 minutes, go out there and squeeze all the stabilizer out. It should seep out of the sock like mush. Should take you about 10 min or so, then you're done.
Day 2 and beyond, balance the FC to the CYA you elected as noted on the
FC/CYA Levels. This chart is your key to avoiding algae.
Always manage your pH in that 7.2-7.8 range. A pH well outside those numbers is what can impact vinyl more than anything.
Perhaps most important - proper water testing. We recommend a TF-100 or Taylor K-2006C tets kit. You can't beat the quality of those kits, and they're easy for the home owner.
Be sure to visit our
Pool Care Basics page for tons of great info. Enjoy the forum.
