New to us pool full of algae
ArkPie
6
Albuquerque
Hi. We just purchased a home with a pool that was not maintained and is currently very green. We put some type of chemicals (a trichlor and something before that) from Leslie's for the last 2 days after we took a sample there, but then my friend told me about TFP. I've read the SLAM article and have the Pool Math app. When I tested this morning, the CYA was quite low as the black dot never disappeared. The app is saying I need to add 11 lbs of dry stabilizer and 3 galloons of chlorine. Is it okay to put some dry stabilizer in a sock in a skimmer and then liquid chlorine in the pool? I've been ready that you shouldn't use both at the same time, so I'm not sure how we would raise both levels. How much dry stabilizer would you add at a time since I imagine it will take quite a while to get 12 lbs added. Thank you!
Yes, that's fine. Pour the chlorine/bleach at the other end of the pool near the return jets. Once the sock has soaked for about 30 min, start squeezing and you should get all of the stabilizer "mush" out.
Good luck on the SLAM Process. If you have any questions let us know.
Also see -----> Pool Care Basics
Welcome to TFP! :wave:
Reactions: ArkPie
