New pool owner since this January. I have been using tabs (tricolor) and powdered cal-hypo “shock” per pool store recommendations until I found this site a couple weeks ago. Got a TF-100 and most recent readings are below:
FC – 5
CC - 0
pH – 7.8 (maybe a bit higher)
TA – 120
CH – 400
CYA – 100 (maybe a bit higher)
I now know that this CYA is high and likely due to previous owner (and myself) using tabs for a long time. I also know I need to raise my FC up to 11-13 to match the CYA level. I’ve been trying to do that over the last week but haven’t kept up with daily FC reduction. Three 121oz. jugs of 8.25% bleach went in this morning.
Been reading a bunch in the forums but still have a couple questions:
- Should I drain and fill to lower CYA to ~50, or just maintain higher FC?
- What’s the downside of maintaining higher FC? Is it just the extra expense needed to initially get it to the higher level? Does more FC mean more chlorine effects from swimming in pool, itchy skin, degrading suits, etc? I believe I understand the “chlorine smell” only really occurs if I have high CC, which would indicate an algea outbreak or the chlorine fighting something, but I’m not sure why if you have high CYA you can’t just keep higher levels of FC and be happy with that.
- What’s the danger of high CH. Is this just a potential issue for the pool equipment? I’ve got some 65% cal-hypo still. Should I definitely not use this due to CH already being at 400?
- When folks talk about testing daily are you doing the quick k1000 test with the colors or the “full” test with the powder. It appears like regardless I need to do the full test due to the FC levels I’m trying to maintain.
- This one is might be a whole thread on its own, but how do so many people get away with shock and tabs. It seems like CYA would just keep getting higher and higher. I have several friends who do this, bring their water to pool store once a month or so and do what they say (which usually isn’t too much, and includes use of Phos-Free every week). I can only think they’re getting lucky. With such a big pool, throwing shock in once a week and keeping tabs in the floaters is clearly much less “trouble” than all this bleach (which also seems like it’s going to be a lot more expensive). Now that I know how the chemistry is supposed to work, I want to do it the right way, but can’t help being just a little skeptical when it seems everyone else does it the “pool store way”.
I’ve got some other questions regarding my pool cleaner setup but will save that for another tread.
Excited to find the forum and very thankful for the help!
FC – 5
CC - 0
TA – 120
CH – 400
