red-beard
- May 27, 2019
- 1,621
- Plaster
- Hayward Aqua Rite Pro (T-15)
It all depends on the area. I have drained mine completely 3 times in the past 4 years without issues.
2017 - The first year I tried to get the CYA out. I did not completely drain the pool, I think 20% left? Well, my CYA was still over 100 when I refilled!!!! I had gone 10 years using pool tablets. I expect my CYA was near 1000 ppm.
2019 - I found this at the bottom of the pool. Mrs. Beard said she would not swim in the pool unless I drained it...
So I did this:
Result: I still had a bunch of Trichlor tablets. So I decided I would "use them up" to get my CYA up. I did not calculate it out using Pool-math. In June, I was back up to 70 ppm from ZERO. So that ruined 2019 for TFP methods! Yes, I could and should have drained half the pool. Or just run high FC levels. Anyway, I went back to playing with the Devil's Pool Candy. I still had mustard algae. And in the spring of 2020, I had oars-men. You have to have algae or they can't feed!
In 2020 I got serious. I drained my pool and was exact on everything. I tested and corrected and did everything right!
The Trouble Free Pool
So I did this:
