So I:
-snapped all the laterals in
-sat the center pipe snugly in the bottom of the Sand Filter
-placed the Centering Key (?) on the center pipe
-filled with water till the level was above the laterals
-began -+slowly+- filling with sand to avoid damaging the laterals (200lbs for Carvin 19 inch Laser Series Sand Filter)
-took off the Centering Key (?)
-attached the Multiport Assembly (put Jack's on the O ring)
-hooked up the skimmer to the pump and the outflow of the pump to the Sand Filter
-hooked up backwash and return jet pipes to the skimmer
-removed the rubber stopper from the return jet and the screw-in thingy from the skimmer
-turned Multiport valve to Filter and turned on the pump...nothing.
Waited for 10-20 seconds...finally the outflow hose of the pump blew off the Sand Filter with water shooting out. Shut off the pump, reattached the hose to the Sand Filter and set the Multiport valve to "Drain". It seemed to work fine. I set it to "Backwash", it was sucking in through the skimmer and flowing out the Backwash hose. Set it to "Whirlpool", it sucked in through the skimmer and pushed out the return jets. The pump was primed, no air--sucking in the skimmer, putting out through the return jet.
So I put the Multiport Assembly valve back to filter, turned on the pump, and...nothing. Let it run for 5 seconds then shut her down. Proceeded to swear angrily and left for work.
So now what?
So now what?
