Long time researcher here, first time posting. We finally bit the bullet and purchased an inground pool this year. It is a 18x40 liner with 8.5’ deep end. I balanced the water and added enough salt to bring it to within the optimum range (currently 3300ppm). I’m struggling a bit to understand how everything ties together, specifically the SWG, Heater, and VSP.
Equipment:
Equipment:
- Hayward AquaRite S3 Series Salt Water Pool Chlorinator
- Pentair WhisperFlo VST VSP
- Sta-Rite System 3 Modula Media Filter
- Nirvana FV140 heat pump
- Does the AquaRite S3 have to be connected to the heater with these 2 low voltage wires? If so, where? (electrical diagram attached). My guess is that it ties into the 3 wire remote somehow, but unsure if it’s normally open or closed.
- Is a check valve after the Heat Pump and before the SWG required? I read on here that there has been some premature failures as highly concentrated chlorinated water flows back into the heater.
- Per the AquaRite manual, I need to purchase a Hayward HLPMPCONV converter to connect to the Pentair VSP. If not, the SWG will just use its flow sensor to not allow it to generate when the pump is off. I think I read on this forum that the flow switch is more of a backstop protection, and shouldn’t be the primary on/off. Is that true?
