- May 17, 2018
- 124
- Plaster
- Hayward Turbo Cell (T-CELL-5)
First post: Our new Cental Florida 10K plaster SWG pool is about 2 months filled. While the builder still sends someone out weekly, I have pretty much taken over armed with the info on TFP and my biochem micro biology background . I started with Aquacheck strips and Pool Math but have been using a Taylor K-2006 kit for accuracy. Our Crystalcrete pool is still curing and I’m using a lot of Muriatic Acid and Bicarb every day or two to maintain a pH between 7.0 and 7.8 and TA 80-120 and the CH and seems to be dialed in to 280. I probably filter more than needed and given the water features and triple Badu Stream II resistance jet system used every day I imagine the pool is aerated alot tending to raise the pH pretty quickly. Also I am keeping the water temp at 80-85 degrees.
My question is: Do I need to wait longer to Borate the pool or can I go ahead at least gradually if I stay on top of the chemistry. I’ve seen “wait a month on a new pool” before borating but does that assume day to day stability is already achieved? I got enough Boric Acid to get to 50 according to Pool Math, but not sure how long it will take this new pool to pH stabilize or if all the water movement aeration from water features and resistance jets are always going to drive the pH up.
Chemically speaking..., I dont know why time matters to Borate if one is monitoring and adjusting all the pH and buffer numbers within range.
Thanks
Thanks
