So we had a pool built last year, and due to weather they didn't get it finished and filled until the end of the season and then immediately closed it, so this is my first time trying to maintain it. I'm having trouble getting the chemistry under control (mainly pH). So first off, the CYA is 0, when I asked the pool guy (who maintains alot of pools, so I thought I trusted him) he said "please don't add CYA, just let the salt system do it's thing for a little bit, too much chlorine will affect the plaster" He went on to say that CYA is great when using chlorine sticks, but with salt "we only use that if we have to". Fast forward 2 weeks. I have the SWG set at 80%, filtering 12hrs a day at 1900rpm (15K gal pool). I still only have .2-.4 ppm FC, pH continues to rise, and I've been adding muriatic acid every day (between a pint and a quart, depending on the acid demand test from my Taylor test kit). So summary:
FC- .2-.5
pH - 8+ (usually 1-2 drops acid demand)
TA - 60
CH - 320
CYA - 0
Is my whole pH and FC problem due to no CYA? Or is it also possibly from the finish being new? I understand that the SWG running alot will cause the pH to continually rise since sodium hydroxide is a byproduct.
Thanks for any thoughts, I don't want to totally blow off the pool guy since there's some things they still need to take care of, but the water is starting to warm, so I might want to swim, and am concerned about the low FC and high pH, since that's a bad combination for safe water.
Craig
FC- .2-.5
TA - 60
CH - 320
CYA - 0
Craig
