Hey All,
Just came across this forum - happy to have found it. We recently re-opened a 27-ft above ground pool that was sitting empty for 10 years. What a chore clearing all that brush and literally pulling every root. But we did it, the new liner went in great, and the pool was filled this week (approx. 17,000 gallons).
Got myself a Taylor test kit and verified there was no chlorine in the delivered water. My initial test of the untreated water went fine, everything right in line (except no chlorine obviously).
Went to my local pool supply store and explained the situation and they sold me 2 gallons of "Liquid Shock". Following the directions I added 1.3 bottles of liquid shock.
I let the filter run about 2 hours and re-tested. My free chlorine reading was 3 and my total chlorine reading was also 3. From Googling, it seems those two readings should always be the same (or very close), otherwise you have a "chlorine lock" situation? Ok, so we got chlorine in the pool.
But my pH went up, 7.8-8.0. I also saw from Googling that shocking can temporarily raise the pH. Is that accurate?
I didnt know if I should just wait it out or go buy muriatic acid to lower the pH. Thanks all!
