- Feb 14, 2021
- 4
- Plaster
- Jandy Aquapure 1400
Just fired my pool guy after six months. Bought myself a Taylor kit and just jumping right in. Thanks for all of the info so far everyone.
Here are the basics:
15,000 Gallon - Mini-pebble, plaster pool. In Ground Pool and Spa, small baja.
Salt water generator and VSP pumps
My PH was at 8, so put in two cups of Muriatic Acid.
My FC levels were at 2.1 - Running my SWG for 8 hours at 60% - Just bumped it up to 65%
VSP is set around 2500 RPM
TA has been about 80-85 most of the summer
CH is 428
CYA was 31 on the last reading
Salt is at 2500 PPM
I picked up some salt to bring the Salt up to 3000.
My main question is regarding CYA. Everything I read says the CYA levels should be around 75 for a SWG, but then my FC levels should be higher around 3-4 according to the chart on TFP.
If I'm at 31 right now, do I need to raise it? If so, by how much? TFP also suggests my FC should be at a 3, not higher than that.
I'm in Southern California and my pool gets sun nearly all day. Usage and bather loads are generally low as we use the pool maybe once a week.
My pool guy primarily put in acid and maybe what looked like a conditioner or stabilizer once in a blue moon. Otherwise our pool has been crystal clear and algae free since inception.
CH is 428
Salt is at 2500 PPM
