- May 16, 2022
- 31
- Vinyl
- CircuPool RJ-45
HI all,
I'm new to TFP and new to pool ownership. The IG pool came with our new house last summer. It is 16 years old. The previous owner decided to not maintain it last summer, so when we moved in mid-August it was a mess. Lots of leaves, worms, etc in the deep end. We cleaned out the debris, vacuumed and shocked. I had the water tested several times at Lesley Pools and they kept telling me I had metals. Finally got rid of the metals but chlorine never registered. Never got the water balanced last summer and decided to get a closing kit and call it season done.
We decided to convert to a SWG this year. Husband installed it and it is ready to go. The first thing it says is to balance the water before starting the generator.
Back to Lesley's and of course we have metals again. Our SWG manual says metal and phosphorous should be zero (they are a big consumer of chlorine and our FC keeps reading zero). Our phosphorous was 2178 so I added NoPhos. I haven't gone back to Lesley's yet because I found this place.
Here are my tests results today using the Taylor K-1004 kit
FC 2
TC 3
pH 7.8
TA 190
The Clorox test strips kept telling me the FC was zero and TC was 3-5 (kept throwing in 2 lbs )
The water is clear but I definitely see algae.
My questions are:
1. Are metals important? I don't see any test kits that test for that but Lesley's seems to focus on this.
2. Should I adjust pH and TA before adding more chlorine?
3. Should I use the SWG to get FC levels up or should I keep adding shock?
Help!
Thank you,
Barb
FC 2
TC 3
pH 7.8
TA 190
My questions are:
Help!
Thank you,
Barb
