We have plans for and are looking to select a contractor for a pool in the Los Angeles south bay area. Details for the current option we're considering:
Overall size: 13' x 37'
Depth: Leaning towards 3.5' to 5.5' for a play/swim pool
Spa: 7x7 with 6 therapy jets
Plumbing:
- recessed commercial type skimmer
- 4 pool returns with directional fittings
- dedicated automatic cleaner line
- 2.5" suction and return for spa jets
Interior finish: Quartzscapes, grey
Baja Bench with umbrella holder
Pool Equipment:
- Hayward 2 HP variable speed filter pump
- Hayward 48 sq ft DE filter
- Hayward 400,000 BTU gas heater
- Hayward Colorlogic LED lights w/ light show (4 pool, 1 spa)
- Hayward Omnilogic remote control system with subpanel
- HydroRite UVO3 UV and Ozone system
Pool Cover:
- Automatic pool cover with encapsulated track system
- Vanishing cover vault
- 3' drainage stub out from vault
Decking: modern flat finish concrete
Would love any feedback! Notes on how we got here and what we're thinking about:
Appreciate any wisdom or suggestions!
Plumbing:
Pool Equipment:
Pool Cover:
- Want a pool cover for safety and heat retention. It's 10 degrees cooler in our area than LA, so trying to extend swimmable months. Solar heating not an option. Would consider any other equipment that lowers heating costs.
- Ozone/UV system due to automatic pool cover and to decrease chlorine level to < 0.5 (though they seem pretty unpopular on this site)
- Every new pool in our area is Pentair, but this PB likes Hayward. We want whatever is best quality and quietest.
- Our pool equipment will be in a concrete-walled area adjacent to an open air cabana. I'm a bit worried I'll be unhappy with this setup later due to noise.
- Originally wanted a FastLane swim jet system but don't think it works with the cover; PB recommended Badu; ended up passing on both after research
- Looked into but ended up passing on Paramount in floor cleaning and Hayward chemical automation after more research.
- Wood deck in plan below was removed due to fire restrictions.
- Still considering porcelain pavers or Chinese sandstone instead of concrete.
