baudilus
What I meant was, you could use a valve for each pair of returns - but a 4-way valve works just as well.
baudilus said:What I meant was, you could use a valve for each pair of returns - but a 4-way valve works just as well.
Looking to break ground as soon as I get the permitting done in Denton ... which requires - beyond the survey and this plan - that I've identified the registered plumber and electrician. Spoke with very accommodating owner of Shotcrete company today. Will continue ID'ing subs in the next 5 days. So, as soon as I'm comfortable, we'll start - it'll take that long for permitting anyway.
Yes, I haven't put the full plumbing plan together (though I have revised the filtration plan below - needs a few more check valves), but I will definitely be running multiple runs to that planter from either side. Our landscape circuit is actually on the right side, so need to do that in order to run the lighting. ;-)
Planning to go all Jandy equipment (controller, filter, 1.5hp SVP pump, waterfall pump if needed, SWG, lighting, auto-leveler, etc.). I like their warranty (for a DIY I think this is critical) and all the reviews I've read have been generally good. Pentair is well reviewed too, but mainly for their pumps, but mixed for the rest of their gear. It's not an exact science, but Hayward has gotten the worst reviews of any of the manufacturers.
This is actually kinda fun. I will retract that - I am sure - when in mid-stream. But for now, fun.
Brentr said:I like your drawing of the plumbing :-D What program did you use? I would like to do one for our pool
frustratedpoolmom said:this is going to be a great pool...
