Yes, that's the reason for Return #7 being in the [almost 90 degree] corner of the tanning ledge. By the way, how deep is your tanning ledge?
We wanted 9 inches of water like you but ended up with 6. Communication issues. The 6 is working out fine, but I'd still prefer 9.
Agreed. I've spent a lot of time working out this issue (on paper at least). If you look at my 2nd drawing, it shows a green 4" drainage pipe running the entire length between the new decking and the existing decking with deck drains every 7' or so to help move any water that may collect in that area. I think this will be sufficient, but let me know if you think otherwise.
The drainage is 1/2 the question and you'll probably be fine with that. The hard part is figuring out the grade from the pool to the existing deck when you only have a couple feet (estimating). The pool will need to be 2-3 or more inches higher than the end of the existing deck. I would think that different PB's will offer different solutions. The ones that I talked too suggested breaking up the existing deck and putting pavers on top the existing deck. I didn't do either. Just highlighting something that may come up.
Speaking of lighting, given the overall size of the pool (~35' x 13' with a 10' tanning ledge), do you think the 2 Pentair LED's on each end will be sufficient (assuming I figure out a way to light the tanning ledge area)?
I'm thinking yes .. 2 is fine.
none of my friends that have pools had to have theirs inspected; in fact, not even a permit is required
Wow .. surprising. I live in st tammany and the parish has a handful of pool specific code requirements and required 2 electrical, a preliminary (for grade), and final inspection. Permit also required. I guess this is a blessing and a curse all at once (for you). Desirable, in that you won't have delays and fees ... undesirable, because you won't have a little extra help from inspectors with making sure everything is in order.
Anyway, I found these Globrite lights from Pentair (http://www.pentairpool.com/products/...lights-454.htm) that are very small and seem to be specifically designed for tanning ledges and other shallow areas.
Nice .. wish I would have checked into those!
Good luck ... looking forward to seeing your progress.
