We got a new pool this fall, this is our first "real" pool, not one of the cheap things from Walmart. Had the pool company winterize it, drained lines and covered. Its a 25' above ground. I need to get an automatic pump I can lay on the cover to keep water from collecting in the cover and pushing the water from inside the pool out of the filter ports and increasing strain on the cover itself. I seen a link to a wayne pump from another post, but this thing looks top heavy and is over 10lbs. Would that work ok for an above ground pool? Thanks
https://www.amazon.com/WAYNE-WAPC250-Automatic-Water-Removal/dp/B008PPPRUK
