Unfortunately I found this site not to long ago and I'm well into my build. Currently finishing up coping and waiting for tile and plaster to be done. Its been a bumpy ride which led me to start researching and stumble upon TFP. I got several quotes before signing on the dotted line. I wish I had found this site before my build to assist in the early stages and made sure I was getting the proper equipment. (all equipment already purchased ) Here goes:
Pool: 15x36
Spa: 7x7
7-8ft deep
99ft Perimeter Pool
28ft Perimeter Spa with Matching Cap & 7 Jets
Standard Pool Engineering to Meet Most
Up-to-date State/Local Building Codes
Pool Excavation and Haul Away of Soil
ONLY (Unless Otherwise Specified)
Installation of Structural Steel per
Approved Engineering
Pool and Spa Plumbing
Shotcrete: Applied Pneumatically
@ 3,000 psi (Higher PSI Will Incur
Additional Charges)
(2) Child-safe, Double-main Drains at
Bottom of the Pool and Spa as Per
VGBA Code Compliance
Waterways Surface Skimmer
Autofill: to automatically fill pool when
necessary
3 HP, Variable Speed Pentair IntelliFlo
Pump and Motor
Pentair 420 Clean and Clear Cartridge Filter
400k BTU Pentair MasterTemp Heater
Pentair IC20 IntelliChlor Salt System
(4) Deck Jets with Extra ½ HP Pump
Dedicated Suction Line (Up to
35')(Vacuum NOT Included)
Standard Timer Box at Equipment
Junction box with GFCI at Equipment
Electrical and Gas Hook-ups and Runs
from Meters are Included
Hose Bib – (if necessary)
(3) Entry Steps as per plan
Safety Bench in deep end as per plan
(2) Pentair GloBrite Color LED Pool Lights
(1) Pentair GloBrite Color LED Spa Light
Standard Flagstone (Up to $450/ton),
Brick, or Poured-in-place (Color/texture
Extra) Coping
6” x 6” Waterline Tile (Up to and
Including Group #3)
Premium Color Stonescapes (Mini Pebble) Pool Interior
(2) Pool/Spa Coping Alarms (as per City
Requirements)
