- Jul 29, 2007
- 115
- Plaster
- Pentair Intellichlor IC-40
I'm sorry - I know I only come around when I need you!
I used the forum and all of the advice on maintaining my salt water pool in So Cal a few years back and was so glad I found you. Now I am looking to build a pool in AZ. Have first quote and would like to get help and advice regarding what's really needed (good equipment etc) versus nice to have. I'm giving myself a tight budget to force me from going design crazy and really just want a good size pool, with baja shelf, to swim and play. I am less concerned about the pool design add ons (waterfalls, colored lights and trying to make it look like I'm not in the desert). Design is geometric (basic rectangle 15x30 3-6ft depth).
My complication is removal of rocks, requiring fill, leveling of the lot prior to excavation for pool. PB has taken into consideration that pre-work of lot will be done prior to them coming in to do pool dig. Based on the adds below, I will definitely include infloor cleaning. Are there other things within the quote that I need less or more of? Thanks
Quote is as follows:
Engineering & Permit:
*Custom Engineered Plan for Structural Integrity
*Permit Approval Sub-Total $843.60
Excavation: Backhoe
*Backhoe Excavation Equipment
*Forming of Pool/Spa & Pre-Grading for Deck Sub-Total $1,791.25
Plumbing:
58 ft. of Main Plumbing Run
*Vacuum Line & Skimmer/ Main Drain Line for Suction on Filter Pump
*4 Surface Returns
*Automatic Waterleveler and install Vac-Breaker Sub-Total $1,619.56
Steel Reinforcing:
*Steel Reinforcing per Engineering Requirements
*Steel every 6" OC Vertical for Extra Reinforcement Sub-Total $1,394.28
Electrical:
*Total Feet of Electrical Conduit includes, 228 ft of 3/4 in.
*GFCI Breaker for 1-400W Clear Light(s) with 45 ft. of Conduit
*E-Command Control Sub-Panel (Hayward)
*Electrical Connection of Pump(s) & Light(s) Sub-Total $2,768.77
Equipment: Vacuum & Return
*525 sqft Cartridge Filter & Variable Eco-Star Filter Pump (Hayward)
*$200 Variable Speed Pump Rebate from SRP/APS -$200.00
*Navigator Suction Vacuum Cleaner (Hayward)
*Aerator & Floating Chlorinator
*Pool Skimmer (Hayward)
*Heat Pump 108-11 OK BTU's(Hayward) Sub-Total $6,274.05
Shotcrete:
*12" Perimeter Beam with 6-8" Walls and Floor of Shotcrete
*Depths 3 ft. to 6 ft.
*Initial Water-Cure of Shell by BUYER Sub-Total $5,757.79
Tile/Waterfall :
*Waterline Tile for Pool/Spa from Standard Selection
*Tile Face of Back and Side Walls to match Waterline Tile Sub-Total $2,148.13
Decking:
*1 078 sqft of Pavers
*Sleeves Included:
*Umbrella/Volleyball (2) Sub-Total $8,379.75
Interior Finish Mini Pebble Standard
& Start-Up:
*Mini Pebble Standard Material for Pool Interior
*Acid Wash & Clean-Up
*Operator's Orientation
*1 Free Filter Cleaning 6 months -1 year after start-up Sub-Total $4,179.46
Total Before Sales Tax: $34,956.65
Applicable Sales Tax: $ 1,837.78
Total With Sales Tax: $ 36,794.43
Options:
*Upgrade Cleaning System to In-Floor Cleaning with 20 In-Floor Heads (Paramount) Adds $2,785.76
*Upgrade Pool Light to ColorLogic LED Adds $386.48
*Upgrade Control to P-4 Control Sub-Panel with Salt Chlorinating Cell Adds $797.67
*Add Ultra-Violet Sanitation System (Trident) Adds $743.51
*Upgrade Pavers to Travertine or Artistic Pavers Adds $2,460.30
*Add 145' of 5' Wrought Iron Fence and 2 Self-Closing Self-Latching Gates & Door Alarm Adds $4,061.69
Excavation: Backhoe
Plumbing:
*4 Surface Returns
Steel Reinforcing:
Electrical:
Shotcrete:
Tile/Waterfall :
Decking:
*Sleeves Included:
& Start-Up:
Options:
