I'm trying to advice a maintenance customer that we service whether or not they should replaster this late in the season (I'm in the mountain west).
I've read through this guide
www.troublefreepool.com
And I've read this guide
www.nptpool.com
And browsing other threads, it seems to be suggested that a slightly positive CSI/LSI is desired for new plaster. If I'm expecting a water temperature in the low 40's, and I target a pH of 7.8, CH of 450, 0 CYA (for now), and Alkalinity of 100, I can achieve an LSI of right around 0. That is slightly outside the range suggested by NPT, which suggests alkalinity of 80 and pH between 7.2 and 7.6, but which would give me an LSI of around -0.3.
Will the plaster still cure fine in this colder temperature? My plaster guy is telling me it shouldn't be an issue, but they don't actually do the start up.
Any concerns with the approach above?
Thanks!
Start-up New Plaster
The first few months are the most criticle for a newly plastered pool. We're here to share best practices to ensure the plaster will last for many years.
National Plasters Council Procedure | NPT Pool Finishes | NPTpool.com
If you’re a builder, remodeler, or home owner with a brand new plaster pool finish, it’s critical that you follow the steps in this guide to protect and prolong the life of your pool finish. Visit NPTpool.com
Thanks!
