Hello,
Build finally finished recently and fill was on Tuesday, today is day 2. It's NPT stonescapes aqua cool mini plaster. SPA spillover is running.
My first test (TF-100 Salt Test Kit) had FC 0 (no color change), ph > 8.2 (darker pink shade), TA 40 and CH 50. CYA didn't even made any difference with tube filled to the top.
I then added Baking soda (qty from poolmath) as part of Day 1 step to raise TA to 80. It worked fine (test confirmed it at 80). Then added the MA per the pool math 21oz.
Day 2- tested again, TA is 80, pH was still >8.2. Added 21oz per poolmath. Waited an hour, tested again and pH is still >8. Added another 21 oz of MA. Waited an hour ,retested and its still dark pink.
I was suspecting new pool start up will need lot more MA. Right now my thinking is to keep adding MA per the pool math and retest every hour until it gets to 7.4/7.6 range. Is that a sound approach or do I need to do something more?
PB is of no help. Appreciate community's help. thank you!
