Thanks in advance! I purchased the below pool and to be honest have not found the intex instructions all that easy to follow. The pool was just filled, I added nine 40lb bags of salt and that's where I'm at
Initial questions:
1) How long do you let the pump run, are there settings and timers I should be aware of?
2) What do I need to purchase to test the water. I notice it included just a few test strips. After trying one, it was a bit of a challenge to determine what was high/low or needed attention.
3) After getting it set up initially, how often do you test the water and what for? What do you use to do so?
4) What cover do you recommend? Ease of use and keeping leaves etc out are top priorities.
5) Anything else a guy should know?
This will be fun!
Pool:
Intex 32ft X 16ft X 52in Ultra XTR Rectangular Pool Set with Sand Filter Pump & Saltwater System, Ladder, Ground Cloth, Pool Cover, Maintenance Kit & Volleyball
Initial questions:
This will be fun!
Pool:
