New numbers
mmmkam
0
May 14, 2015
13
VA
I think the numbers are looking pretty good at this point, but the TA is a hair high. Just looking for a sanity check and wondering if I should be doing anything to adjust the TA at this point?
PH 7.5
FC 4.5
CC .5
TC 5
CH 375-400
TA 85-90
CYA 70
Salt 3450
Thanks in advance!
For your current numbers there is no need to adjust your TA. However the numbers represent just a snapshot. I expect when you look at how your numbers are trending, you will see pH that increases with regularity for this season due to your plaster being pretty new. In that regard, if you do see continuous pH increases, you may wish to lower your TA to 50-60. It will help to stabilize your pH if that is an issue.
