First of all, hello everyone! A few months back, the wife and I decided to randomly purchase a 18'x48" Coleman Steel Series Above Ground Pool. I came across this forum and have read many of the articles concerning leveling the ground and ways to accomplish this (we dug down and then leveled using the 2x4 trick, we then used anti-fatigue mats). I also found out through the forums that a building permit might be required, thank you because it turns out that my town did require it. The pool has just been finished being assembled and filled this past Sunday 06/05/2022, and now I am on to my next learning moment. Chemistry and end of season. I have started digging into these a little bit, but apparently not enough. We purchased essentially a bag of each of the recommended products (alkalinity increaser, ph increaser, ph decreaser, etc.) but did not realize how much might be needed to get started out of the gate. We used city water to fill the pool (7700ish gallons from what I gather) and after testing the water for the 1st time, it showed I needed to add 14ish pounds of alkalinity which is what made me realize that we were way off on how much we initially bought. As of right now I am showing per the clorox test strip (with app use): 110 Hardness/0 Total Chlorine/0 Free Chlorine/7.2 PH/0 Total Alkalinity/0 Stabilizer. So now on to some of my specific questions.
1) Once I get the levels to where they should be, how much product should I maintain on hand for upkeep through the season (through Labor Day weekend I'm guessing)?
2) Am I correct in, if I use the 14lbs of alkalinity increaser to raise my alkalinity that I will probably also have to use a ph decreaser afterwards (assuming the ph will rise from 7.2 when using 14lbs of alkalinity increaser)?
3) I saw some "starter kits" available to purchase, are these worth it? Am I correct that they don't do anything for the alkalinity/ph balance?
4) I purchased a chlorine floater and 1" chlorine tabs to put inside. Do I just fill it up or should I limit how many tabs I put inside of it?
5) I live in Southern Maine, am I able to winterize a Coleman (type) Pool or will it be necessary to dissemble at the end of the season?
6) What is a good landscaping product to go around the pool? We were thinking about using rubber mulch and solar lights if it is safe to do so.
Thanks in advance for any help on the above questions.
