- Jun 21, 2011
- 51
- Vinyl
- Solaxx (Saltron) Reliant / Purechlor R5
I've read through most of the previous threads on spa water care, but not finding the exact answer I'm looking for, hoping someone can comment from experience. I have a new Intex PureSpa with built in SWCG, that I'm working on developing the right water care regimen for. This model has the built in SWCG for sanitation and I have the salt level correct at 3000ppm per recommendation. I've ran the SWCG for 8 hrs overnight the last 2 nights to see what the net effect of FC was each morning. The first night/morning there was zero by 10:00am (spa is under a covered porch and covered the whole time, so zero sunlight hitting water). This morning (after another round of 8hr sanitation cycle (SWCG) I tested around 1.5 FC and .5 CC (with TF100 testkit it took 3 drops to go to clear, and testing for CC did put water back slightly pink, but cleared with 1 drop). So, what I think is going on is this......with initial setup and fill of the spa this past Sunday, the only sanitation has been the two overnight 8 hour cycles of the SWCG Tuesday night and last night. I didn't initially treat with any sort of spa shock or anything.....only thing added to the water at this point was a little bit of TA increaser to get the TA up from zero. I am working toward figuring out what cycle and frequency is needed with the built in SWCG, but what I'm looking for immediately is the best way to add chlorine manually to get FC up to safe use level, which I understand is 2-4ppm FC. I've read the thread and articles about not using CYA in spa, as it hampers the effectiveness of chlorine to do it's job, and how that's much different in spas than pools. What I don't know, is which form of chlorine is best for quick spa treatments, but still safe. Thought I had read somewhere that said not to use bleach in spas??? Suggestions? I realize I'm not providing a full set of test numbers, but I can get that if it'll help.
