New home with pool, should I switch to SWG?
ik91
Active member
May 10, 2023
34
Cary, NC
Hello,
I recently moved into a home which came with a 32x16 plaster pool and if I calculated it correctly it has approximatelly 18240 gallons. It has been covered with a safety pool cover since it was closed last summer by previous owners. I did partially take cover off today and it is green but not dark green and can see to bottom of pool.
I wanted to know if I should convert to SWG as I have heard it it is easier to maintain and if I should convert should I wait to open the pool and get a SWG installed now or should I go ahead and open the pool now and SLAM it? I have attached images of the setup as well. I have ordered the pro kit from tftestkits and awaiting for it to arrive.
Stats:
Pool Filter: Titon II TR-100HD
Pump: Jandy Pro series Flopro 1.5 HP
Hayward CL220 chlorine feeder
Polaris PB4-60
Polaris pool robot
Unknown Intex timer in my garage but I don't know if that control the pool or not.
I'd get started cleaning the pool and balancing the levels once your test kit arrives. Until then (if it's longer than a few days), you might consider adding 5ppm of liquid chlorine to prevent algae from getting worse.
Once kit arrives, I'd pull the cover, get pump running and water mixed well. Then take a sample, clear out any leaves or large debris, and commence SLAM.
I think a SWCG is a no-brainer, especially given the cost of chlorine today.
Reactions: ik91
You can start researching SWG options while your test kits are on their way. Doesn't look like you have automation, so you have plenty of options to choose from. If automation is in your future plans, then just make sure you consider that when you are choosing.
Here's a good resource to read up on and a comparison chart:
TFP recommends a SWG that is rated for at least 2x your pool size, so in your case you'd want something in the 40k range. There's certainly no harm in going bigger as that can help with lifespan of the cell as well.
Another thing to consider based on your photos is the SWG cell placement. It appears your returns are sitting directly on the ground, so want to elevate it for easier access (possibly with two 45 degree fittings or something).
Do you guys think that intex timer is for the pool even if it is located in the garage which would be far from pool equipment? Also, I saw some local pressure washing companies sell liquid sodium hypochlorite and wanted to know if that is safe for pool chlorination?
That is the major ingredient in chlorine. If you look at any pool chlorine bottle or even regular laundry bleach, it's the same thing. The only difference might be the percentage strength.
As for the SWG timer, if I understand your question, I think it should be near the equipment pad. Typically that's where you need to see everything together in case there's an issue. But we can give others time to respond.
Reactions: ik91
I don’t currently have a SWG. I have a intex timer in my car garage which I don’t know what the purpose is for but I have seen people have similar timers for their pools. I was just wondering if that time me controls my pool filter at all but in my opinion that would be a odd location given my pool equipment is not close to the garage.
I don’t currently have a SWG. I have a intex timer in my car garage which I don’t know what the purpose is for but I have seen people have similar timers for their pools. I was just wondering if that time me controls my pool filter at all but in my opinion that would be an odd location given my pool equipment is not close to the garage.
Flip that switch to the left to turn on and see what it does maybe it’s outdoor lighting it turns on arround 8 and shuts off at 1am if timer set correctly
Reactions: ik91
Silly question, but just to make sure .......... are you positive that's an Intex timer and not an "Intermatic" timer?
Reactions: ik91
Sorry you are correct and it is a Intermatic timer. I do have landscape lighting in the home but they are on their own timers outside so I am unsure what it could be for. Guess I have to wait to open pool which will be this or next weekend to tell if it is for the pool or for something else.
Reactions: Texas Splash
I am opening my pool today and wanted to know if my valves are supposed to be this way for opening or should I turn them?
have taken out plugs in pool, gizmos, and installed drain plug in filters. When starting I was going to filter to waste first as well.
The two together need to be opened. The one by the other wall is your waste and should be open if you are going to filter to waste.
Reactions: ik91
How do you tell if the two are open or closed? This is how I found them and has been like this since pool was closed last year by old owners. Also, is single one by wall supposed to be closed normally if not filtering to waste?
All three are now closed.
Yes.
Reactions: ik91
I opened pool and have following results from my Taylor pro kit.
Ph: 7.8-8.2
CYA: <30
CH: 425
TA: 90
I want to SLAM the pool and have liquid pool chlorine ready. Should I lower Ph and raise CYA first?
