Does water flow into the skimmer when you're running water into the pump or the skimmer? But just doesn't fill the skimmer up to where it overflows the mouth?
When I stick the hose into the pump I get water boiling up into the skimmer, but the skimmer never fills it just stays at the same level.
Is there two holes in the bottom of the skimmer? If there is plug the second hole and try running water in it again.
Yes there are two holes, the intake and then the equalizer. If I plug the equalizer the skimmer still doesn't fill.
Sorry if this hasa been covered but i didn't go back and read the first page.
Not problem, I appreciate the help.
Are you sure you put the hose in the line to the pump and not into the equalizer line?
Yes, I even thought maybe I had the two holes backwards. So I plugged the intake, and plugged the equalizer hole in the pool and filled the skimmer and the water held. I unplugged the equalizer hole in the pool and the water drained. Then I plugged the equalizer in the skimmer and put the hose into the intake and let it run for 20 minutes, and there was no change in the water level in the skimmer.
If the pump is above the pool water level, then you would have to pressurize the water going toward the pump in order to see any water at the pump.
The pump is above the pool.
My next question then is why will my skimmer hold water at the level it is currently at and not leak out? That is with the equalizer plugged.
For instance if I fill the pool up to the skimmer and then shut the water off, the level will go drop back down 4 inches below the skimmer. But inside the skimmer the water level doesn't completely drain.
[attachment=0:28mly34a]skimmer.jpg[/attachment:28mly34a]
I am wondering if it has something to do with the other intake? Where would that second pipe coming up to my pump come from? The middle drain?
