You all have helped me so much with my SWG pool that it is now easy!! Hoping to get to that same place with my hot tub, which at this point I hate.
I have read everything, including the how to use Bromine sticky - our preferred method. This weekend during our unusal 2 days of summer we purged using Ahh-Some, drained, scrubbed the tub and all jets, filled, ran another purge with Ahh-Some, drained and refilled again. I tested the fill water TA (40), CH (75) and pH (8.2). Based on these readings we added Hardness Plus, pH decrease and Baking Soda and then added the appropriate amount of Leasure Time Sodium Bromide - let all this run overnight.
Today I tested the following pH (8.2), CH (75), TA (40), and got no reading from the OTO test for Br (not surprising since I didn’t add any shock).
So my question now is should I shock or wait to deal with the too high pH, too low CH and too low TA? What should I do to lower the pH and raise the TA? I think I should wait on the CH as that may take a while to register, correct?
Also, should I be doing the TFTK chlorine drop test? Will that show me my Bromine level?
Thanks everyone for all your help!
