New CircuPool RJ60+ - Generate Light
Feb 27, 2015
180
Grand Rapids MI
Hi everyone - I'm on week 2 or 3 of my new CircuPool RJ60+. Been loving it so far. I have a question about the Generate light. Should I expect this light to be on the whole time that the SWG is running? I've gone back to look at it a few times randomly throughout the days and sometimes I go back and it is not on, but the SWG is on. I then turn off the SWG and turn it back on and the Generate light is once again on. My thought was that it always needs to be on when running, but I wanted to verify.
The system is set to run at 75%. Any thoughts?
The generate light is only on when the unit is actually generating chlorine. If you have it set to 75% then it will generate chlorine for 75% of the time the unit is physically powered on, so the generate light will also be on for 75% of the time it’s physically powered on.
I believe it’s been reported that the unit works on a 180 minute cycle. So if it’s set to 75% it will generate for 135 minutes, then rest for 45 minutes, then the cycle repeats.
Reactions: jandersen13
