Replaced my cell and all seems well except for the 16V 5A reading. Is the 16V okay? Water chemistry is as close to perfect as it can be.
Donnie
Donnie
JasonLion said:Higher power levels at the same run time uses up the life of the cell more quickly.
I suspect you have a low level algae problem, enough algae to use up chlorine, but not enough to show up visually.
Bama Rambler said:The first thing to do is shut the swcg down and run an OCLT to make sure you are losing FC at night. Once that's done you'll know if you need to shock. If you do there's an article in Pool School on how to do it correctly. And we're here to help too.![]()
Yea...i scrubbed the do-do out of it with a fairly hard bristle brush and it wouldnt budge. Still no CC's as of 6:00 this morning. FC at 32 and the wife juat added a 1/2 gallon at noon. Actually a cool day 75ish with cloudy skys. Hopefully I've destroyed whatever was in the pool.Bama Rambler said:What you're seeing is most likely a stain. You can try holding a vitamin C tablet on it and if that doesn't work hold a trichlor tablet on it a little while.
