New Build Plumbing Pressure Test
palmettoinspect
0
21
CHARLESTON
We just had our plumbing completed on our new pool build. I've been watching the gauge set by the plumber and it went from 22 psi to 15 psi in about a days span. Then down to under 10 psi the next day. I've searched but couldn't find a clear requirement for testing. Should the pressure hold constantly or is the reduction I'm seeing just the pressure equaling out or something?
The equipment has since been set so I don't know if we will be able to test again?
Good question. I'd be a little nervous about that. Sometimes the rubber bungs can let a little air past them and lose pressure. Is your plumbing configuration such that you can plug off the returns and pressurise from the skimmer?
Yes, I think so. The hose bibb is still in place at one of the skimmers and the returns are still all capped. The pump and filter have been set but can't I just turn the valves to closed and repressurize the lines and see what happens? This is my first pool so I have no idea really.
