Hi everyone
I posted previously during my planning process and I appreciate all the help/advice. I ultimately settled on a fiberglass by Latham called the Barcelona. It’s a 16x38 rectangle with a small ledge in shallow end and a bench at the 7’ deep end. Delivery date is set for 4/28/21. Timing was a big deciding factor in me choosing fiberglass over over vinyl despite the higher cost, as I had hemmed and hawed long enough that the vinyl contractors became booked until 9/21. Builder has a good (albeit small) reputation for “high end” work, grew up in my town, and has a retail location here too. He is the authorized dealer for latham and leisure.
I also purchased a H2X Trainer 12’ swim spa that will sit parallel to the pool And will be delivered on 4/26. Crane for pool itself will lift that from driveway to its location on 4/28.
I didn’t expect work to start till late March, but PB texted me 2 weeks ago saying he’d like to come get the electrical set since permit was approved quicker than expected. Im working from home anyway so no big deal. Trenches were dug, electrical run (inspected/passed), water line run, existing pavers ripped up and reset afterwards. Need to upgrade service to 325 amps heat pump, swim spa, and enough for a pool house/she shed with heat/ac down the road) but all wiring to separate garage (which will get a new sub panel) and equipment pad is done. They also set up the pad and and equipment, which I’d didn’t realize was happening until after it was done (had a busy day with conf calls and when I came out they were gone for day and pad was down). They used plastic pads. i don’t think that I specifically discussed the pad details with the PB, but wondering if anyone has significant concerns. They told me about and fixed the busted French drain pvc, and sprinkler line was repaired.
besides that, everything is looking ok to me, but it’s just electrical and equipment. Posting pics and will update as it progresses.
thanks again
Chris
thanks again
Chris
