Never has this happened
Cowfd13
11
East Meadow, NY
13,000gal, above ground, 76 degree water
just opened yesterday
I tested the pool with the TF-100
CH - 0
PH - below 6.8
TA - goes to red immediately w/R-0008, not green
CYA - 90
Borates - can’t check. Test strips must be bad, everything tests 90-100, even a Poland spring bottle
I have NEVER in 8 years seen a PH below 6.8, our fill water is 6.9. I had to add about 18” of water after removing the cover to start filter.
So far, I’ve added 1lb of 73% cal-hypo and one box of Borax (70oz)
new test:
CH - 10
PH - still under 6.8
TA - still untestable
Help??
What would cause this major anomaly and where would you start?
Texas Splash
33,136
Fiberglass
CircuPool RJ-45 Plus
You need to get the TA up ASAP. For whatever reason it crashed taking the pH with it. Very corrosive. Use enough baking soda to increase the TA in increments of about 30 ppm at a time, let mix for about 30 min and re-test and add as necessary to get your TA up to about 60-70. Also try to aerate as much as possible to help the pH rise. Keep us posted.
Reactions: Cowfd13
Donldson
5,100
NW Ohio
I heartily second Pat: get that TA up quickly.
Did you happen to put some sort of chlorine floater in the water over the winter? Opening to no TA and a CYA of 90 is somewhat rare as typically the opening and closing process gets some fresh water which lowers the CYA and raises the TA. Having trichlor pucks in the water over the winter would be one possible explanation.
Reactions: Cowfd13
Cowfd13
11
East Meadow, NY
Ok I dumped baking soda and waited - retested and got 30. Dumped more for now, but I think I need to consider dumping soda ash on the next go, so I can bring up the PH at the same time
any thoughts on how this happened??
Texas Splash
33,136
Fiberglass
Anything at this point is just speculation. Something acidic would've been the #1 assumption. Aside from that, I'm not sure what chemical process might have occurred over the winter. It's good you are seeing some rise in the TA. I would follow-up to ensure you get it well into the 60-70 range. Even if you over-shoot a bit it won't hurt. Then monitor the pH a bit before adding anything else. With the TA and aeration, you might find the pH rise on its own.
Reactions: Donldson
Donldson
5,100
NW Ohio
Your pH is already going up with the TA, test both pH and TA on your next test and if your pH is still low then very carefully and conservatively dose soda ash. Undershoot whatever you think you want to hit because there's a good chance you will see a higher rise than PoolMath will calculate. You can always add more, but having to add acid after all this would be painful.
How did it happen is a good question. Did you test your water before closing? It's really odd because one way TA could drop is if a bunch of rainwater got in, but if that happened your CYA would also have been zero. If your CYA is about what it was when you closed then your TA should be too, unless something acidic was added between your final test and first test.
Reactions: Texas Splash
Cowfd13
11
East Meadow, NY
I did not test immediately before closing, because it was tested 3 days earlier. We swam in it. I actually decided last minute due to incoming weather, to close it then - instead of 2 weeks later as planned. My last test was:
CH - 3
PH - 7.2
TA - 65
Borates - 35
CYA - 60
none of it makes sense. We gained no water - we actually dumped 12”, then lost 6” between hot fall days and a slightly late opening. Although my pool is in the 70s now, the top 6” were 94 when I opened it.
Cowfd13
11
East Meadow, NY
I did retest PH when I tested the TA and got 30, it was still below test kit level (under 6.8)
I’ll retest in a few mins and update
Texas Splash
33,136
Fiberglass
Nice. Continue the aerating. Aerating would be idea to lift the pH. If the pH doesn't creep up to 7.2 by tomorrow morning, consider adding a little baking soda to get the TA up to 80.
Reactions: Cowfd13
JamesW
27,195
CH - 3
PH - 7.2
TA - 65
Borates - 35
CYA - 60
What was added after this test?
The only way that the TA could go to zero is if 1.5 gallons of acid were added.
Maybe someone added acid and they thought it was liquid chlorine?
Cowfd13
11
East Meadow, NY
Literally nothing. And no one touches the pool chems but me. I don’t even have acid on the premises, because I’ve never needed it.
Cowfd13
11
East Meadow, NY
TA does not just disappear.
Either the test was wrong or acid was added.
Multiple tests were not wrong. I have no idea how acid could’ve entered my pool over the winter while it was covered and locked. It’s ridiculous to think someone snuck on my property to sabotage it, and I literally don’t have acid. 8 years I’ve never needed it - and I didn’t want it on the property unless I did.
either way, currently I have TA - 70, and PH 7.2
it took almost 12lbs (there’s about a pound left in the bag, so 11 was used) of baking soda to correct it.
oh, and now that those have leveled off, my CYA is registering at 30. So the ph or TA being so low, must have affected the CYA test.
