chem geek said:You might consider getting an ammonia test kit from a fish/pet/aquarium store. If your FC got to zero at some point, it's possible bacteria converted some of your CYA into ammonia and that would take a heck of a lot of chlorine to get rid of it -- up to 2.5x the amount of CYA that is lost so 25 ppm FC (cumulatively added) for every 10 ppm CYA.
Also, you can use a bucket test to see the actual chlorine demand where 1 teaspoon of 6% bleach in 2 gallons of pool water would be 40 ppm FC. Of course, you should first find out if you really do have any chlorine in the pool by using an OTO chlorine test (or FAS-DPD test).
I was at 0 FC pretty much since I opened. The FC initially jumped up but then settled back to 0. I had shocked numerous times with recommended shock levels and then even exceeded the levels with 10L then 20L and now overdosing with 60L of 12% chlorine (I went nuts).
Is it possible with the cold temperature (I opened at 50 deg) that bacteria would convert CYA into ammonia? Since I dumped in a boatload of 12% liquid chlorine would that resolve the ammonia issue if it existed?
The OTO chlorine test now shows 3.5 % chlorine total and free
