- May 23, 2015
- 24,472
- Plaster
- Pentair Intellichlor IC-60
Since you are in an HOA you must have gotten approval for this project. The HOA certainly can't force your neighbor to take down the fence for construction but, as long as your project is approved and you follow all of the HOA rules to the best of your ability (ie, keeping common areas clean and free of obstruction, respecting any work hour limitations, etc), then your project can proceed and you can take whatever time you need to get the excavation done properly. Excavating companies that do pool digs are very resourceful and are used to working in tight environments. If you were on a big open stretch of land, they'd bring in the 2-ton excavator and dig it out in half a day. If you're in a tight yard, they'll use bobcats and small diggers as well as a few poor unfortunate souls with shovels and wheelbarrows. They are going to dig that hole and they'll figure out the best way to do it.
Ignore your neighbors and be the bigger the person. They are simply grumpy busybodies that want to tell everyone else what to do but wouldn't lift a finger to help when asked. You can't control their bad attitudes or behavior but you have 100% control over how YOU respond. Paying back unkindness with unkindness never ends well; simply go about your business and do what you have to do. Follow the HOA rules and let those neighbors stew in their own anger. You are better than their childishness.
