Need to replace Pentair pool light which has 5.75" dia face plate
Mar 3, 2016
33
Gold Canyon, AZ
Need to replace Pentair pool light which has 5.75" dia face plate but the closest size I find online is 6" so I am concerned that the retaining screw and bottom lug will line up with existing fitting as I think replacing the can would be a real pain which would necessitate drilling or cutting into the gunite.
Reason I want to replace it is because it keeps tripping the gfci even though light is dry inside. If I bypass the gfci then light will stay on. I have replaced the gfci but problem remains. Tried to get an electrtician to look at it but after 2 months and broken appointments and phone calls to other electricians in area never returned I have concluded that replacing the light is the only way to go as a do it yourself project as I am somewhat electrically challenged.
