With a CYA of 30ppm, you've GOT to keep FC above 3ppm at all times. This means adding enough bleach either at night, or in the early AM before the sun rises to raise the water's FC to 7ppm. You're going to lose roughly 50% of your chlorine every day. So if you lose 50% of 7ppm, you remain .5ppm above your minimum at day's end. Then you re-dose the water in preparation for the next day.
At these low FC levels you're working with, you're consistently under 3ppm. It's no wonder that the FC is being lost, there isn't nearly enough in there to get you through any one day much less a few hours.
Chlorine is depleted by sun and organics. Elevation has no relevance to this. If you can see the sun and have swimmers, the chlorine will be used daily. Sometimes I can get away without dosing because the clouds shield the UV rays (and no one swims on such days) but by the next day I have to add a full dose just as if it was sunny and people swam.
Bring FC up to 7ppm each night. If you lose more than 4ppm the next day you've got a problem and I'd recommend shocking the water. If it settles at the end of the day at 3.5 or better, rinse and repeat every day.
