The network of piping at the exit of my filter (so the flow at this point only has to go through a bunch of pipes, the SWG and out to the jets) has this open piece of PVC, which used to serve these solar panels I've disconnected. Now, the open part is about 7' or 8' above the pump level, so I guess that means there isn't a lot of pressure, but there is enough that the water is coming trickling out. But since I don't want the floor of my pool shed to get wet, the lesser of 2 evils is not running the pump, which I so badly need to do. So I need advice to stop it up so I can run that pump again.
