Need help with valve parts
dschlic1
757
Valrico, FL
The diverter valve on my solar heater has bit the dust. The cover and swing arm (inside the valve) are badly worn. The problem is I cannot see who the manufacturer or part number is. This information appears to be on the backside of the valve which is against the wall of my house. I went by my local pool store. They had a diverter valve replacement kit for Jandy valves. The stub shaft on the bottom of the swing arm is much smaller on the Jandy unit. So the unit is not a Jandy. I need help in identifying the valve manufacturer so that I can purchase replacement parts Here are some photos:
104438104439104440
The other sid eof the cover is covered with paint, but has no identification markings on it. This valve has an electric operator, so the handle may have been changed. I did find that it is a Hayward valve, but the simple expedient of ordering one from Amazon. When it arrived, I took it apart and the pieces matched. Interestingly the rebuild kit was almost twice the cost of a complete valve!
