Hey guys, I’m a new pool owner and I have an issue with the pump and/ or sand filter. When I turn the pump off, it sounds like the filter drains and there is a slight hiss coming from around the valve. I have noticed that when I bleed the air out of the filter all the noise stops. However, after a few minutes the pump will lose its prime. I’ve removed all the plumbing and retapped with new Teflon and made sure (from what I can see) there are no leaks. There is a check valve located between the pool skimmer and pump basket, no other valves in the setup.
we are leaving for a few weeks soon and I won’t be able to put this on a timer when we are away so if anyone could help that would be amazing!
thanks,
Mike
thanks,
Mike
