Need help identifying replacement clamp band for filter (Pentair?)
NewWorldViking
Active member
Aug 3, 2018
27
Cottonwood Heights, UT
The nut on my filter's clamp band has stripped out due to age & use. The bolt isn't faring too well either. I need a new clamp band but I can't find any brand or model number on my filter. It looks like the label fell off or was removed. The only number I can find on it is on the band itself. The instruction label says "Label #98728400" which may or may not be helpful.
I'm pretty sure the filter is a Pentair (everything else is).
I *think* it's a Clean and Clear Plus. Looks like it at least.
The clamp band is circular and divided into 3 solid U-shaped arcs strapped together and held tight with a T bolt, spring and long brass nut.
I found the Pentair 190003 clamp band and it looks identical. But is this the right part?
It's description is concerning me. It says the height is 2 1/4" which is about right, mine is actually 2 5/8". But it says it is 22 1/4" wide whereas mine is more like 21 1/2" when tightened down. It also says it's 23 1/4" long but I assume they are accounting for the bolt & spring.
Does Pentair have any clamps that look identical to the 190003 but are a slightly different size? Or do they only have 1 clamp that looks like the 190003?
